Daz DIM - Mark as installed
Is there a way to mark an item as installed, after download in the DIM?  Some items that are Poser structure, I choose to manually install, as I have a folder layout structure that I prefer.  If I open the downloaded zip, and install it manually and remove the zip...it appears again in the Ready to Download list in the DIM.
I see you can hide a product, but I worry if it is hidden, that I won't see future product updates?
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,430
    You need the zip or the manifest for updates to work - you could always install to a temporary folder, then move the fiels around as you would have directly from the zip.
    edited March 2017
    Yea, I guess that is the best plan...though I will have to keep changing my install path, based on if its a Poser or Daz format item. (though the former is getting less and less theses days)
    Thanks Richard!
    Post edited by 3dOutlaw on
    If you have the Show Details checked in Ready to Install you will get a new window at the bottom that has a button to easily change between libraries.
    I added a feature request, for what it's worth.  Request #311820
    Is there any way to download the "Manifest Only" for a product?  I can use a TEMP download directory idea above, and move files from there, but since I have thousands of products already...I could not practically re-download them all to get the manifests.
    Never mind, I just found I can use the Display hidden toggle to see if anything popped up in the Product Updates area.  So I can "hide" everything I installed manually.
