Clothing Morph Question
I have a set of clothing morphs that I like to work into each set of clothing I buy. Fit Control for genesis 3 enables you to load morphs into the clothes on the figure by having the figure wearing the clothes selected. Is there a way I can create morphs that will load into the clothing just like fit control loads them or do I have to custom makes the morphs over and over?
  • Richard HaseltineRichard Haseltine Posts: 112,021
    As long as the morph has AutoFollow checked in its parameter settings dialogue (reached by clicking the gear icon on the slider) DS will try to project the morph into the clothing and other fitted items, if they don't already have a morph with the same name.
  • As long as the morph has AutoFollow checked in its parameter settings dialogue (reached by clicking the gear icon on the slider) DS will try to project the morph into the clothing and other fitted items, if they don't already have a morph with the same name.
    Thanks Richard! So help me through this. Say I have a shirt and I want to make the sleeves roll up. I select the shirt and create a D-Former. I D-Form the sleeves how I want and select "Create root control parameter" and "Delete Applied D-Former(s)." I then spawn the morph which then appears under morphs in parameters section of the shirt. I then enable AutoFollow under each morph controller like you said. Now when I load a completely different model shirt, how do I make those same morphs apply to it? Is there a step I am missing? I am still a bit unclear.
    Morph trasfer is to the fitted item from the item fited to - from a Genesis to its hair or clothing.
  • Thanks again for your response Richard. I'm sorry but I'm not an expert at Daz and am still a bit confused. I might not be accurately articulating what I want to do. I basically want to be able to apply my custom morphs from one shirt to other pieces of clothing(shirts) without having to go through and re-deform each new piece from scratch. Is the transfer utility able to do this and if so how? I was wondering if there was a way in Daz to actually save certain morphs from one piece of clothing so I could apply only those morphs to another piece just by clicking on my saved morph file. Kind of like loading clothes onto a figure by double clicking the wearable file.
    You could try fitting the shirt without morphs to the shirt with. You could also try saving a DForm preset and applying that to the new shirt.
  • Fitting the shirt without morphs to the shirt with didn't work but I made an individual D-Former preset for each morph. I then took the new piece of clothing and applied each D-Former and spawned them into the clothing one at a time. It's important to note that I made sure only one D-Former was applied every time I spawned the morph because, otherwise, it would include all the other morphs in as well. This will save me the time in the future of having to create new D-formers whenever I get a new piece of clothing. So I  guess there is no way of making a type of custom Fit Control setting but at least there is a faster way of creating the same morphs for new clothing. Thanks for your suggestions Richard. It helped me solve the issue in a roundabout way.
