wolf 2.0
I just puchased Wolf 2.0.  When I load the figure, it has green hair nodes that outline exactly the look I want upon render. After rendering, I have a short-haired wolf...Where did I go wrong????    (newb)
  • Richard HaseltineRichard Haseltine Posts: 112,059
    The green hairs are the guides, they will be chnaged to "real" hair when you render in 3Delight. If you are using Iray you need to export the hair as OBJ or fibre hair from the Look at My Hair interface just before rendering (or at least, after posing and morphing) then load that back in via File>Import.
  • tophandtophand Posts: 141
    Thanks Richard.  I was rendering in IRAY   that would explain it
