Argos Hangar
dash2128dash2128 Posts: 736
Does anyone know how to locate Argos Hangar in DasStudio?
After downloading and extracting it, I had trouble locating it. I eventually found 1 button that merged the interior set into a scene. But I could not relocate it again when I searched for it. When I enter 'Argos Hangar' in search box, 2 Argos Hanger lighting buttons come up, instead of the set button I located before.
Also: That makes a total of 3 items (buttons) that I have located. Does Argos Hangar have more to it? The description says it has moving doors, ect... I'm not sure what I'm getting, but the set looked like something I could use.
Right now I can't locate it in DazStudio. I need to find it.
  • WilmapWilmap Posts: 2,917
    I can't help as I don't have it, but here it is in the shop
    http://www.daz3d.com/argos-hangar
  • frank0314frank0314 Posts: 15,115
    Were are you looking for it. In DAZ Studio Format of Poser Format in the content libraby. I don't have the pack but would guess its in Poser Format/My Library/Figures
  • Richard HaseltineRichard Haseltine Posts: 111,839
    The readme should tell you which folders to look in in the Content Library pane. It may not have metadata to make it work with the Smart Content pane.
  • jerriecanjerriecan Posts: 470
    It's by Nightshift 3d - it should be under Poser Formats, then look either under Figures or Props look for Nightshift3D. That's where most of his content defaults to, I believe.
  • adamr001adamr001 Posts: 1,322
    Yup, it's in Figures/Nightshift3D/
    There are all of two end-user facing files in the product,
    ArgosHanger.cr2
    ArgosHanger.lt2
    Expand the item on the scene tab and you can see the doors, etc. Select a door and then on the parameters tab there's an open/close. Pretty much all of it can be moved.
  • dash2128dash2128 Posts: 736
    Thanks, Everybody!
    You helped me find it!
    And learn a little more in the process.
    Newbie 21
