Help with "white" skin - no texture showing
I'm running into something of a problem that I cannot ifgure out. I'm working on an image series and not doing much with assets other than changing poses and environment (keeping lighting the same when possible). The first 4-5 images came out perfect, but now I'm running into a situation where only 1 of the 6 figures on the screen is showing a skin texture when I render - the rest are just white space in the shape of a human wearing clothes (and yes, the clothes, hair, and props render fine). Working in 3Delight across all renders.
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Most likely this is the issue with a corrupt AoA SSS Shader file in the temp folder - on Windows go to C:\Users\YOU\AppData\Roaming\DAZ 3D\Studio4\Tempt\Shaders\Brickyard and delete the contents, that will force DS to rebuild the file next time you render.
