Can't cast shadows without Dome Environment
Hi, I am pretty new to DAZ so that I might be doing something wrong. The problem I am having is that when I add lights and switch from Dome + Scene Environment to Scene Only the shadows are not cast when trying to render with iRay, when I use Dome Environment everything works fine.
Is there anything else I should do? For the way I am setting up the lights I am sure some shadow should be reflected on the floor.
Thanks a lot for any tip in the right direction! :)
    Iray lights always cast shadows but you must have something in the scene for them to be cast on to.
    Thanks a lot, so it is not like with the dome environment that I don't need a surface? I will test that. Thanks
    The dome has a surface. Draw Ground defaults to ON. See attached. There will be a "surface" even if it isn't visible
    498 x 756 - 64K
    Thanks a lot! that did it.
    Always learning something new ;)
