creating clothes
How to create clothes for victoria 4. Transfer utility only seems to work for genesis.
Also when i have created clothes with tranfer utility there , Cloth doesnt seem to contain any morphs.
  • Richard HaseltineRichard Haseltine Posts: 111,929
    edited January 2013
    The transfer Utility is for TriAx figures (Genesis, the horse and so on). For Victoria 4 the route is usually:
    Open Figure Setup pane, use pane menu to copy V4.
    Right click in the group list area and import the grouped clothing OBJ
    Drag the clothing OBJ into the hierarchy, replacing the V4 geometry
    Remove unneeded bones, or remove the V4 geometry from bones that are needed to anchor the clothing
    Add bones for and handles, for skirts etc.
    Check the Modified selected figure option and click Apply
    Edit joint settings as needed.
    The Transfer Utility does not create morphs by default - you can sett hat option, or you can simply rely on the auto-generation of morphs as you use them (or create your own morphs).
