two questions about D-forms and g3f
Two questions:
1) When I apply D-forms to g3f, it seems that it only works if I first zero her pose. With v4.2, e.g., that was not necessary. Am I doing something wrong?
2) I modify g3f with a few D-forms and then spawn a morph. Works great. How can I make that morph get loaded with g3f by default every time? That is, I want that slider to appear with every instance of g3f.
thanks!
1) basically, D-former work best with zero pose, zero morphed status. or you may feel difficulity to controll handle direction, correspond to effect precisely. or often lost Field.
Even though you set D-former with zero pose, after that apply pose, D-former effect still not much with handle direction as true meaning. this problem still remain, if you use D-former influence weight map with zero pose, then apply pose, after that try to controll effect by influence weight map.
2) after spawn a morph, you have new parameter. then you only need to save it as new morph for G3F correclty.from top menu>save as>support asset> morph asset(s) , then choose the parameter, which you made.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/modeling/tutorials/pbms/start
untill try to save as morph, you may better read detail how to save morph, flom this link, (save morph section) to understand where the new morph.dsf will be stored.
Thank you. I will try this today.
