Error when loading a ds file into DS 4.5 Pro
I get a msg to the effect that an object needs to be selected, etc when trying to open a ds file from the FILE menu.
I'm relatively new to DAZ Studio so ... bad file/install maybe?
Should a ds file normally open using the OPEN cmd?
Post edited by Elowan on
If it says an object needs to be selected then you are probably trying to load a texture. You need the original item selected before you can apply textures.
What item are you trying to load?
Yeah - it turned out to be a defective file. That's what I get for forgetting to take my omega3. Thnx for the reply
