85% vs 77%: Can you explain the iRay status.
ScavengerScavenger Posts: 2,677
edited March 2017 in The Commons
[85% vs 77%: Can you explain the iRay status.} Pretty much as said...
340 x 285 - 69K
  • exstarsisexstarsis Posts: 2,128
    Did you change the rendering options? I've noticed that when I adjust the render quality mid-render... the percent done never drops back down but the convergence will.
  • RobotHeadArtRobotHeadArt Posts: 917
    edited March 2017
    They are measuring two different things.  The message in the collapsable pane is the convergance.  The percent on the progress bar is how much convergance based on the Rendering Converged Ratio.  If you set Rendering Converged Ratio to 50% the progress bar will say 100% when the convergance reaches 50%.
    Post edited by RobotHeadArt on
  • marblemarble Posts: 7,500
    Ahh - so simple after all. I had often wondered about that too. Thanks.
