Import ZBrush .Obj to Daz Studio 4.9
Hi friend,
I have a big problem when import Obj from Zbrush to Daz Studio 4.9 64 Bit  in Trasfer Utility
When i change morph character
I explain my path...crying
- Load Genesis 3 F and in Parameters > Mesh Resolution > Resolution Level  BASE + SubDivision Level 0
- Send to Zbrush
- i work my T-shirt, Armor etc
When i Import the .obj file in Daz and i use Trasfer Utility > change the character morph > and change pose , my .Obj it completely destroys ... trying to follow the Source "Genesis Female"
Plz someone can Help me !?
Thx so Much
  • If you are working on a  orphed figure you need to tell the Transfer Utility which morphs are being used (the Source Shape button) and then in the extended options you need to check Reverse Source Shape from Target. That won't be as smooth as if the model was made for the base shape, but it should be usable.
  • edited February 2017
    Thx for respond me Richard...
    I post the Screen..
    Reverse Source Shape i can selected only in Morph metod selection ! Sure ?!
    But i don't know which i will use morph...
    1683 x 1008 - 605K
    Post edited by salvatorepicagraphic on
  • Try selecting "Current", with the figure in the state in which yousent it across to ZBrush.
  • Realy Cool...
    This configuration  is also valid for other model of characters !?
    Victoria 7, Michael 3, Aiko ... Etc ?!
    1081 x 984 - 292K
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Yes, to an extent - one thing you do have to watch for is transforms (scaling, rotation or translation), those do need to eb zeroed before sending the figure mesh to ZBrush.
