How can I zero the figure pose to 100%?
mikekmikek Posts: 195
When I select my figure then zero->zero figure pose the figure scale will change to some strange value like 97 or 87%. How can I get the figure to zero to scale 100% or leave it instead of setting a strange percent value?
  • BeeMKayBeeMKay Posts: 7,019
    In Parameters, select Scale and click on the lock. That will keep the scale from going away from the value you selected.
  • That may indicate that a shape, which wouldn't be affected by zeroing the pose, is driving a scale adjustment.
  • mikekmikek Posts: 195
     Yes that works perfectly. Thank you.
    You are right it was from a shaping as after setting them to zero it resets again to 100%.
