Clothes won't stay on the body.
Why won't the clothes stay on the body?
1920 x 1040 - 275K
  • TooncesToonces Posts: 919
    On the right hand side, in the scene tab, make sure the clothing shows up as a sub-node of the figure. If it doesn't, right click on the clothing and select 'fit to'. Change the fit from None to the figure.
  • Being parented (appearing under the figure in the Scene hierarchy) doesn't guarantee that the item is fitted - it can be parented but not fitted or fitted but not parented. Instead you should look at the Parameters pane, where there is a Fit button that should have the name of the wearer if the item is fitted or None if not.
