resetting default shapes/morphs for genesis base characters
How do i reset gen 1,2 and 3 base shapes for the characters... I have uninstalled,, both the software and the starter essentials packs,,for all genesis characters,, but no matter what i do when i load them they sill come have morphs loaded.. I have done zero, which does zero them,, but i am pretty sure they arent the right shape,, ie big body,, small head.. and if i do a restore,, then yes you guessded,, moprphs load a again.. I have sinse leanred that before creating a new character you should start with a fresh base character so as not to get in the situation i am in now.. So my lovely fellow dazists what do i do.. ??..
Some properties, not from the base, have been saved with non-zero default values. Load the figures and look at the Currently Used group in Parameters to see what is in effect.
OK yes I have found which ones they are,, so how do i rest thoese or zero them
If they are from a product, try reinstalling that. If not, click the gear icon on the slider and set the default value to 0, then use File>Save As>Support Assets>Morph Asset to resave the morph using the supplied values for Author adn product (so it overwrites the existing copy). Mouth Realism HD and Navel should be set by default, if you chaneg those the next update will reset them.
