Genesis 2 Female: remove/shorten eye lashes on one side?
I'm trying to remove or shorton the eyelashes on one side of G2F (She has an eyepatch and it's poking thru).
It looks like Genesis had a morph for each side, but I'm not finding something for G2.
  • I don't know that I've ever seen a hide one eyelash solution.  If it were me, I'd take the Opacity map for the eyelashes and make a copy and modify it so that the eye with the eye patch doesn't have lashes at all.  Then just plug it back into the Opacity channel.
  • ScavengerScavenger Posts: 2,677
    That's the option I'm planning on if nothing else is found.
  • L'AdairL'Adair Posts: 9,479
    I don't believe I've ever seen a morph for the right or left lashes. There are two morphs for removing lashes, but they work on both eyes. (Not sure if those come with the free figure bases or if they are part of the add-on morph packs, though.) I've got one for removing all transmapped lashes that came with the Oh My Lashes product from Rendo. You could also remove the lashes using the Geometry Editor. Create a new surface with the polys for lashes on the side you need to remove, then click the eye icon next to the new surface in the tool settings.
    Oh, a quick copy then edit of the opacity map is very easy to do..and very easy to undo should I wish....
    The eye patch was made for genesis and has controls that do left and right sep. I imagine that option was removed for G2.  i can understand simplfying but it makes like giving a character a single cyber eye more complicated than it needs to be.
