gen3 materials..?
2»
  • The file is correctly placed for the content directory set-up you have, however if DS is telling you that that file is missing it may indicate that the database shows an install with Connect too and that that file isn't being found - if there is a Connect installation DS will use that in preference to a DIM/manual install.
  • 1234MATT1234MATT Posts: 222
    ok,,, so i got rid of every alternate libraries now there is only one in each of the primary locations,,,now what goes in the daz connect spot-where does it point to ,to be correct,,,?
    whats the defualt installation for a "connect library?"
    As Richard said there is nothing wrong with having Connect point to one of your regular libraries, I just don't like it from an origanizing stand point (I am slightly OCD that way).
    yes me also ,,,if you couldnt tell....so... whats the default location for Connect?
    edited March 2017
    I don't ever use defaults but I think it was something like C:/Users/Public/Documents/DAZ 3D/My Connect Library.  If it wasn't there is no reason it can't be.
    Edited to add:  I hate the way Connect has been implemented and only use it for one Connect only product I bought.
    Post edited by jestmart on
  • Richard HaseltineRichard Haseltine Posts: 111,382
    C:/Users/YOU/Documents?Daz 3d/Studio/My DAZ Connect Library I think - certainly it was in the personal folder not the public.
    ok, it is still there...i will go thru preferences to make sure it point there,,,really thanks
    ok, i found and fixed the connect directory,,,,,,,the thing that is happening now is that after i load a figure"gen3" or others,,,,in the parameters panes lets say you switch
    to add a material. it will still say that the file doesnt exist,,,when it plainly does exist and if i use "in a default lay out" the panes o the right side such as content library,,,it will get and apply the material as long i use the "merger into scene " selection in the drop down box,,,,,is this normall to always use the merege option?
    No, that still sounds like a problem with the Content Management System.
    the cms is a totaly blind subject for me,,,where can i look to find any thing to start off in a good direction?   thanks
