After GenXing... the most efficient way for file settup is...?
wancow
Okay, I'm learning, I really am!
And I want to know if I have this right. So I GenX a character, or any character creation for that matter.
I have found that Scene files that are based upon Characters I have SAVED AS CHARACTER PRESETS are smaller than those I simply GenX and save to a scene file.
Traditionally, I'll simply GenX a figure, and save it as a scene file...
Now, is my question is this; I'm not quite understanding file organization in DS...
Can someone enlighten me as to things like, Imported Props, etc... where should I save those props first? I believe this also is important to do with Poser File import...
And how are these files organized when I save them in the correct manner?
Post edited by wancow on
What format are your imported props in? If they are PP2 (Poser) files, then they should go into the My Library/Runtime/Props folder, so that both DS and Poser can read them. If they are not PP2, then Poser can't read them anyway.
What's the difference between importing a PP2 or OBJ with regard to how DS organizes DSF files?
You don't need to import a PP2 file, DS can open them anyway. As long as they are in a Poser runtime folder, DS will display them in the Content Library pane. OBJ files can be imported, and then saved out as a Scene Subset (DUF) or some of the other DS formats if required.
DS content does not have a rigid file structure like Poser, as long as the DS items are inside the My Library folder, and it is listed as a DS content folder, then they will be seen by DS.
I'm aware of this. However, the size of a DUF scene file will be radically smaller if you save your character as a character preset as opposed to saving it in just a scene file without going through that previous step. Try it.
