Need help with GoZ
FantastArt
Hello, I'm trying to do some headmorphs for A7 and V7. I did this with zbrush using the GoZ . Everything worked fine so far, but now it seems I did something wrong when I saved my character in DazStudio. All the morphs are gone. I made several headmorphs and saved the character but when I load the characters in Daz, only one of them shows the zbrush morph option in the parameters. Can someone tell me how to save the morphs step by step?
I think you have the GoZ part correct. Where you may be having a problem is knowing where/when the morphs are saved.
After you have created the morph in ZBrush and sent it back to DazStudio onto a particular object (onto the character object or onto a wardrobe object or some other object),
the morph information is with that particular object in that particular scene. If you save the scene it will save the morph in with that object's shape information in that scene. It will not save the morph back to the original character file, it will only store the morph in that scene file.
You can save the object from the scene as a Scene Subset and it will include the morph in that Scene Subset file, so that you can then use that object and morph in another scene by bring in the Scene Subset instead of the content library V7 figure.
If you have a wardrobe item fitted to a figure in a scene and you morph the figure, if you only save the wardrobe item from the scene as a Scene Subset it will not include the morph. Because the morph is associated with the figure not the wardrobe item. If you had morphed the wardrobe item instead of the figure it was fitted to then the morphs would be saved in the Scene Subset.
Hope this is of help.
