ATTN: TheAntFarm (or anyone)
Griffin AvidGriffin Avid Posts: 3,884
edited February 2017 in The Commons
I want this item.
http://www.daz3d.com/denizen
It says :
UberLight is a 3Delight light shader, texture maps, and custom interface allowing powerful and flexible lighting control in DAZ Studio. The new light allows for high-end controls, allowing the user to place light where it is desired with the use of enhanced falloff controls, barndoors, and light gells (gobos).
1) Is that the light inside the suit that makes the face port glow?
2) Do I NEED this to use this product or is it just for the style of the promo pics?
3) Will this work in iRay as the required light product is for 3Delight?
Post edited by Chohole on
  • It should work i Iray with a bit of fiddling - metals do tend to need more than the auto-conversion but there are some shadrs included with DS (under Shader presets>Iray) that should help, and if you want a glow from the face plate you could either use a standard light (the default spotlight used not to have fall-off with distance, I suspect that's why uberSpot is requried, but in Iray all lights have fall-off) or apply the Emissive shader preset and adjust the luminance and temperature to taste. To apply shaders, select the surface(s) and the object - in most cases the Surface Selection tool will work - then double-click the preset.
  • Okay, I'm off to the shop!
