Magix 101 - IRAY worlds skydomes not appearing in renders
I got this product after hearing that IRAY skydomes do not appear in renders unlike the 3DL versions.
However I cannot get the skydome in this product appear either.
I would have studied the instructions but none are provided with this product so any ideas folks?
  • ScoopeyScoopey Posts: 191
    I can't get the IRAY worlds to produce a visible backdrop!
  • Do you have Draw Dome on? Is there something in your scene that may be blocking the Iray dome (a modelled skydome, for example)?
    Checked for a modelled skydome
    Tried Drawdome on and off with same result.
  • Richard HaseltineRichard Haseltine Posts: 111,489
    edited February 2017
    This discussion was created from comments split from: Iray skydome is not visible in the DAZ Studio ViewPort..
    Combined two postings of the same question.
  • Oso3DOso3D Posts: 15,119
    It should create a Iray Worlds object that has a Base (horizon and ground), with Sun and Skydome parented to it.
    If you aren't seeing anything like that, you aren't doing something right...
    Worked it out eventually...
    From 3DL days, I always set up my scene and cameras and then added the skydome.
    With the IRAY Worlds skydome when it load it adds a "scripted" camera...if you do not render with that camera then the skydome does not appear!
    That's why you need some instuctions or warning to use the camera "supplied"!
  • glaseyeglaseye Posts: 1,312
    Erm, created a new camera, 24mm wide angle, rendered just fine...
    600 x 400 - 186K
    Hmm I wonder if it glitches is you use an existing camera in a scene! I always create a new camera when I start a scene and in my case "Camera 1" did not draw the skydome.
    Anything is possible... As you say you created a new camera 1st, I did try that also..
    Loading the dome 'as is' would replace the whole scene, camera(s) included, with the Iray dome scene. As such, I did 'merge' the scene to 'preserve' the existing camera 1. It still rendered fine.
    That's the hard part with finding a solution to the problem; with so many different systems and their setups, it is not always possible to replicate a problem from one system on another...
    Post edited by glaseye on
