Reset prop to content default?
RiverSoft Art
Hi, somehow I messed up a prop from a package. I was playing around with posing and creating pose presets. At one point, I needed to use a prop and position it, and wanted to save its location in relation to the pose. I created a Properties Preset. But now the prop is ALWAYS moved when it is loaded, even on a new scene. I have tried to uninstall package that contains the prop, delete package, and reinstall. But the prop is still moved no matter how I do it! How can I reset prop to its default from the Daz store?
Thanks,
Tom
Bonus question: what is the proper way of saving a prop for a pose preset?
It sounds as if you must have saved a morph asset which controls the offset, though deleting the files from the Data folder should clear that (assuming that's what you deleted between uninstalling and reinstalling).
How would I find this morph? I uninstall and delete the package. I check the Data directory and it is gone. Reinstall, and the prop is still moved!
Thanks.
Load and seelct the prop, then in the Parameters pane look in Curently Used.
Hi Richard,
Sorry to be such a noob. :-) I see the parameters that are currently used (rotations and translations). And I can reset them... but I want the default object reset. Do I need to make a new preset (I assume Properties preset) and copy it back into the My Daz 3D Library?
Thanks,
Tom
Click the gear icon on one of the Currently Used parameters and select Parameter Settings. Is the Default value non-zero? If not lok at the Controllers tab - is anything listed?
