Ex-Connect Confusion?!?!
KA1KA1 Posts: 1,012
So firing up DIM a few days ago I suddenly had some "New products" as well as some updates - thinking nothing of it I went ahead and installed it all.
That "New Product" was the previously Connect Only Detective Bundle so I guess the whole Connect Only for the first year then DIM enabled has happened - potentially now though I have been duplicating installs I originally installed with connect which have now been DIM enabled - as I was okay with Connect Content back then I have no idea how much space I may have used with duplicate installs!!
Anyone else found this??
  • Pack58Pack58 Posts: 750
    You can turn off ex-connect only in your DIM filters if you downloaded them all with connect then you won;t see 'em and accidentally redownload them.
    Unfortunately that isn't working - even if you have Connect Installed off in DIM you will still see the unencrypted ex-Connect Only items.
    edited February 2017
    Strange. A few days ago I couldn't find Make A Wish Props in DIM untill I changed the "Connect Available" filter.
    But I hadn't installed via Connect.
    Post edited by Pack58 on
  • LindseyLindsey Posts: 2,017
    I uninstalled and reinstalled with Daz Connect those products what recently went off DRM.  In DIM, I hid those products on the Ready to Download Tab.
    You can validate if the files are not DRM by looking at the files in the Prouct's the Daz Connect>Data>Cloud folder:  The files should not have an .enc file extension.
