multiple node visibility on/off
Hi, I hope someone can help me. When working on a Genesis figure, I had good use of choosing a node, say, right shoulder, and then select children. When all children were selected, I could go to "all" in the parameters tab, and then it would show the slide bars in a combined way. For example "Twist(8)" where all twist-bars were gathered. Most useful was the "Visible (18)" where all the node visibility on/off bars were gathered in one. Then just click and the whole arm and all fingers disappeared or reappeared.
Now, for some reason, all these bars show up separately, so I will have to click the visibility bar for every single node, all 18 of them. I hope there is a way to get back to the former setup, which was at least 18 times more practical.
I remember this was working on the DS 4.8, but because I have had a long DAZ-pause, I'm not sure if it worked after I changed to DS 4.9.
there is a visibility pose selection you can use,
I also saved a few of my own for other figures so can just apply
the third tab in save Pose is where it hides, uncheck everything else
one I use a lot for G3F and M that shows only head neck and topmost chest, works a bit on other figures too
change extension txt to duf
In the Parametrs pane option menu - the lined button in the top corner, or right-click on the pane's tab - make sure that Consolidate Properties is checked and Display Separate items isn't.
Thanks a lot!
