Some smart content is now showing
Hello there. I have an issue with content not showing in smart content and for me to see it I have to go to the Content Library and search for it which is really troublesome to do. I read that if it's an old model it won't have metadata to show or something like that, but what about newer ones? Can this be fixed? Thanks.
Here is an example of one I can't see:
ps. I tried to 'Search known directories for Files...', 'Process metadata Queue', 'Re-import Metadata' none of them fixed the issue though.
Post edited by evilcho_ on
I am gussing they are just not build in? Is it hard to do manually?
That's not a Daz item so it certainly won't auto-add itself to the Content Mangement Service. |If the zip contains a \Runtime\Support folder it may have metadata which could be imported, if not you would have to categorise it yourself (a quick way is to right-click on the BKCBoyfriendShirt folder and select the option to categorise the whole set of folders).
I tried that, but it still doesn't show in smart content>wardrobe>shirts
Try this tutorial, I think it's the best you can find: http://www.daz3d.com/forums/discussion/20018/metadata-tutorial-adding-new-items-to-your-smart-content/
Thanks. This helped even though I wasn't able to do it for this product (I think because it's just not meant to be added there to begin with) I think it's a good reference for future ones.
You can - or should be able to - add an item to any category, there's nothing in uncategorised items that can block them. If you want to make it appear in Smart Content when Filter by Seelction is checked it does need to be marked as Comaptible with its wearer, whichc an be done by dragging from the Content Library to Smart Content while the wearer is loaded and selected in the scene.
