HDRI's - any tutorials / descriptions
Hera
in The Commons
Aany good descriptions out there on how to use HDRI's?
http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/21981/21981_quick-start-guide-to-the-iray-dome-and-the-use-of-hdris.pdf
this is pretty comprehensive
Pretty straightforward. If you got them from the Daz shop you should just be able to double click them. If you got a map from somewhere else, they go in Render Settings>Environment>Environment Map. Use the dropdown. See attached.
You can then rotate the dome to get the light where you want. Use the other settings in the Render Settings>Environment tab to turn the dome and ground on and off. You won't get a view of the dome unless you have Iray preview mode on. Need more?
