Update has broken iRay :(
I have updated and now I can't render in iRay. I have loaded a scene that has rendered well in the past, but now I don't get anything. Help!
2017-02-03 19:15:09.038 Rendering image
2017-02-03 19:15:09.071 Iray INFO - module:category(IMAGE:IO):   1.0   IMAGE  io   info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
2017-02-03 19:15:09.118 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating geometry.
2017-02-03 19:15:09.118 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using OptiX Prime ray tracing (3.9.1).
2017-02-03 19:15:09.118 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing geometry.
2017-02-03 19:15:09.118 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 26 triangles, 1 instance yielding 26 triangles) took 0.000343
2017-02-03 19:15:09.119 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
2017-02-03 19:15:09.120 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 1 textures, 0 lambdas (0 unique)
2017-02-03 19:15:09.121 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.00s
2017-02-03 19:15:09.121 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
2017-02-03 19:15:09.155 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
2017-02-03 19:15:09.155 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
2017-02-03 19:15:09.156 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
2017-02-03 19:15:09.156 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
2017-02-03 19:15:09.156 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
2017-02-03 19:15:09.160 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1 layer frame buffer
2017-02-03 19:15:09.169 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
2017-02-03 19:15:09.169 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: Cannot render: found no usable devices.
2017-02-03 19:15:09.169 Iray Render error: Invalid parameters (NULL pointer).
2017-02-03 19:15:09.296 Saved image: C:\Users\Henley\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2017-02-03 19:15:09.345 Finished Rendering
2017-02-03 19:15:09.458 Total Rendering Time: 0.61 seconds
2017-02-03 19:15:25.348 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
  • BeeMKayBeeMKay Posts: 7,019
    Two things come to mind: if you have an nVidea card, have you updated to the latest driver?
    if you don't have a card, have you selected CPU as render engine? The update might have unswitched the setting from the saved scene.
  • l_stowel_stowe Posts: 172
    I am going to have to look into the graphics drivers actually. I noticed in the log that it mentions no device found, so I turned the CPU back on again in the render settings and it started to work again, allbeit slowly.
    wish me luck
  • Yes, the new Iray version in the new D|S update needs a "recent" driver version, otherwise Iray can't use the card at all. I think it's been mentioned before that the cutoff version seems to be 372.
    Note, though, that older cards (although still capable of running Iray until this update) might not be able to use the most current driver; my card is in the old-and-creaky-but-still-works category, was never able to do Iray, and can't use a driver newer than 342.
  • I ran into this same issue with the latest update as well. I was using driver 362.00 (happily, I might add, as it was extremely stable), and had to update to a newer post-372 driver. Now I am facing the same dilema I was faced with last year; finding a stable driver that doesn't crash under harder renders.
    I've tried letting Windows choose the driver, and it chose 376.53. Iray works now, but now is not stable... I've been running into the same I used to have with past drivers; my GPU's sometimes decide to stop working and randomly kick over to CPU-only (even on simple scenes). So it looks like I'll have to continue searching for a stable driver.
  • frank0314frank0314 Posts: 15,100
    Nvidia drivers are hit and miss for me. One will work but the next won't and I have to roll back until the next is released.
    372.90 is stable for me and works without compliant in 4.9.3.166
    I've just downloaded and installed the Geforce experience software (which I could have sworn I had installed a few months ago) and I found that my drivers were 368.69 which seems a little out of date. So, I'm just downloading a further 350MB file to bring me up to speed. I'm going to pray that this work and makes my PC work better with DAZ again.
    wish me luck!
  • JerifeJerife Posts: 272
    edited February 2017
    Thanks for the tip Fastbike1! Gonna try it
    Unistalled 376.33 and installed 372.90. This night will see
    Post edited by Jerife on
    Latest verion seems to work fine with me... phew. Crisis over.
  • jurajura Posts: 50
    Hi there
    Personally I use 373.06 which works flawlessly on my GTX1080 or Titan X
    Hope this helps
    Thanks,Jura
