Just Curious: Click and nothing happens when ADDING TO....
Sometimes when I'm trying to load something in a scene or onto a figure, the loading daz display that usually shows the loading process and any relevant info, pops up for a split second and then dissapears.
And nothing happens- so I'm basically saying it's a failure to work- possibly compatibility or some other error.
I usually just say "Oh, I can't do that" and try something else.
For an example. I'm creating a genesis figure and applying the materials and bits from other characters.
Clicking on BASE MATERIAL UV worked and changed the skin to theirs.
Clicking on an EYE changed the eyes to the other character....
until I pick some stuff and it flashes that screen but doesn't change figure.
I assume it's an incompatible ...material.....since some of those same choices work, but some don't.
Maybe some have MDL and some do not. Maybe it won't load iRay materials...or something...
  • Richard HaseltineRichard Haseltine Posts: 112,049
    edited February 2017
    Well, if you applied an Iray preset that matched the 3delight preset or vice versa there might be no visible change in the viewport. Also, some effects do not show in preview at all.
  • Ahhh. Thank you, sir
