Add expression morphs to mask from another figure
ColemanRugh
I fitted a Genesis 1 mask to Genesis 2 and it fits great. But, the mask doesn't follow any of G2's expressions.
Is there a way to add G2's expressions to the G1 mask?
Thanks for any help!
It's been a while since I used G2, but I think I remember having to turn on AutoFollow for the expression morphs as they are off by default.
You can do it fairly easily by selecting the figure, right clicking in the parameters tab, and selecting Edit Mode. Then go down to Pose Controls for the head. Click on the top one in the list, then scroll all the way down to the bottom and shift click on the last one so they're all selected. Then right click on one of them, scroll up to AutoFollow, then click on Enable AutoFollow on selected properties. Then you can right click in the parameters tab again to turn off edit mode.
After that, you'll have to reload the mask and fit it to G2 again, then the expressions will work. This process doesn't make any permanent changes to the expressions unless you do Save Modified Assets, which can be risky.
Awesome!! Thanks so much!!
