Preset question
in The Commons
Which preset should I use?
I want to save a figure with all of its morphs and pose settings. I have tried character preset, pose, preset, and properties preset.
character preset saved the morphs but not the pose. The pose preset keeps the pose but not the morphs. Properties preset might work, but it didn't seem to be quite correct in my test (maybe I did something wrong).
I'm sure someone here knows, and there isn't much point in me wasting hours scratching my head.
I think you would have to save it as a scene subset (a scene would save everything) to get both the morphs and pose. If there's anything else in the scene that you don't want saved (i.e. lights etc) they could be unchecked and ignored. Then you'd merge or load the subset next time. Every other preset is designed just to save the one particular property, not multiple ones.
You need to use the tabs in the Properties preset to set what is incouded - by default, as I recall, only the first tab is enabled.
Ok thanks, yes it is the Properties preset that I needed.
