Lip sync problems
Hello
How do you get the key frames and the audio you imported to show up at the same time.  I must have did something wrong because I can play my audio file and lip sync it to my character, but no key frames show at all.
Thanks
Dave
  • What keyframes are you looking for - on the speech movements? Those may be on the head if they aren't on the figure node.
  • I don't really know.  I was watching a youtube video, and it showed all his key frames with a dot.  Each time he changed a animation frame.  Then right under it showed the audio.  When I play my animation.  My character mouth moves and the audio plays, but the key frame dots are not there.  I was in sequencer and moving my audio a few frames back.  Them when I came out of sequencer, none of my key frames were showing.  My video still plays, but I can't delete any key frames if I can't see them.  When I sa the youtube video with the key frames, and the audio below.  I thought it would be so much easier to sync my video with my audio if I could see both at the same time.  I just can't get there.
  • Was this in Daz Studio? Which pane was being used? Do you have a link to the video?
  • DekeDeke Posts: 1,636
    I've never been able to play audio with the lip sync shot in Daz. I've only been able to export the video, often as a low-res (not Iray) .mov and then sync up the video and audien in a program like Premiere Pro. I see if the sync matches, make adjustments, and re-render. Do this until you have the effect you want, then do the full-res render.
  • Rendering to an image sequence and assembling that in Premiere may give better results.
  • When i click on analize in lipsynch it gives me message
    "some channels defined in the current configuration file could not be found on the figure. lip-syncing may not be as accurate as expected. see the log file for details"
    please help !! and thanx
