Problem exporting an FBX file with face key from iclone.
Has anyone had recent problems again with exporting from daz and bringing that FBX file with iclones face key into 3DXchange? I know this was a problem several months ago but with Daz new update it was fixed. But just recently as of about 2 weeks ago it started happening with me, where everytime I tried to open an FBX file with a face morph ( exported from Daz ) 3DX crashes. I've wiped Daz from my computer several times, reinstalled as per their techs suggestions and the problem persists. I have a second computer with Daz and when I export from there into my main computer ( the one with the problem ) it works just fine. So obviously there is something the older program from Daz has left behind that's interfering with a smooth transition. But I don't know what. Anyone have any suggestions?
  • Just wanted to try this again, anyone else encounter this problem?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,653
    you can try replacing the FBX exporter  dzfbxexporter.dll in the one that does not work with the one that does
    I had a similar issue once with the Optitex advanced dll not updating
  • you can try replacing the FBX exporter  dzfbxexporter.dll in the one that does not work with the one that does
    Do you have any idea how I would do this with Daz? I'm clueless.
    Thanks for the reply.
    I meant the actual files in programs DA3D DAZ studio 4 plugins
    rename the extension of the one you are replacing to bak so can undo if needed
    you need to have seeing file extension enabled for windows
