Any suggestions for a good plywood shader
I need to render a nice looking plywood shader. I haven't had great luck with Carrara wood shaders but I'd guess that is my limitations.
I've looked around the internet a bit, but I don't seem to see shaders that address the raw edge of plywood ( the layers)
Thanks
Brad
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,678
    think that could be more of a mapping job
    create a separate domain in the vertex room on the edge and use scanlines
    it may be doable in the shaderroom too with layers and insets if you do not wish to change or find the object's UV mapping unsuitable
  • StezzaStezza Posts: 9,264
    edited January 2017
    Just used shaders from the woodland pack and got this in about 2 minutes for a piece of 3 ply using shading domains.
    640 x 480 - 74K
    Post edited by Stezza on
  • PjotterPjotter Posts: 274
    Search google images for plywood texture map.
  • I had done some searches with plywood texture map, I didn't find anything I could use. But I did have luck with shading domains
    Thanks
    B
