Rigging two objects to move together
I am working on a car model in Hexagon, which I intend to rig in DS. One of the things I want is to have various doors open, and the front wheels pivot as if turning a corner. Is there a way to make both front tires pivot together on one dial? Likewise, I'd like to rig a fold down seat so the bottom moves laterally and the top pivots flat at the same time. How do you link movements in two axes on one dial?
You can create a Pose Control.
After that click Accept.
Your Pose Control should be located in the Parameter Tab in the Node of the figure you chose. Using that slider you will now be able to open the trwo doors at once.
If you need more controls, just repeat the process with different poses.
Remember it is important to go back to Zero Figure Pose between each ERC Freeze, just in case.
Did this answer your question?
If you need an in-depth guide to rigging tools - I always suggest my own Comprehensive Guide to Rigging Tools for DAZ Studio.
Thanks Thomas. When I get done modeling it, I'll check your guide.
Thomas Windar thanks man that worked a charm on some front car wheels. Thanks to Google and you I had no problem doing my first ERC freeze.
