Mars 360 questions
Could you please help me in setting up this item. I cannot see it in the image screen so how do I set it to use other items on its surface.
Thanks.
    It is an hdri so you will only see it in Iray preview mode. If you  can change the preview mode from what you are using to Iray that way you can see how it will look.
  • Charlie JudgeCharlie Judge Posts: 13,629
    Also be sure that 'Draw Dome' is turned on
  • BendinggrassBendinggrass Posts: 1,388
    Thank you both.
    That is a great help.
    Does anybody know if these HRIs are actual photographs of the Martian surface?
    edited January 2017
    I don't believe it is. I believe it was fabricated. I think it is a good purchase though. Even when you turn off the skydome form rendering the lights are pretty different and unique.
    edited January 2017
    Thanks. I was more interested in one with true images. I did find a reference where someone put one together from NASA images back in 2004 (http://forums.cgsociety.org/archive/index.php?t-116022.html). Unfortunately the site where it was hosted now seems to be defunct.
    Post edited by Charlie Judge on
  • These were rendered in Terragen, The lighting shadows comes from where the sun is placed in the scene. I had to send them to a render farm or it would have taken month to render.
    In theory you could import some mar data sets and render your own scene in Terragen. But I'm out of practice these days
  • nDelphinDelphi Posts: 1,974
    edited January 2017
    I did not know this, wow, that long?
    I used one of them to great effect in this scene, the Heliades-class space exploration vehicle was rendered to scale with the figures. I added a haze environment box to the scene to add haze to the atmosphere and turned on Iray's bloom effect. I rendered this one as high as 7680 x 7680 and another one at 7680 x 4320 with a GTX 1080:
    http://www.3dlibrarian.net/2017/01/28/heliades-class-space-exploration-vehicle/
    Post edited by nDelphi on
    @nDelphi  "I used one of them to great effect in this scene, the Heliades-class space exploration vehicle was rendered to scale with the figures. I added a haze environment box to the scene to add haze to the atmosphere and turned on Iray's bloom effect. I rendered this one as high as 7680 x 7680 and another one at 7680 x 4320 with a GTX 1080"
    My congratulations, that is a wonderful work of art.
    These are one of my favorite HDRI sets. They work really well for a variety of things from offworld renders to post apolyptic and war renders not to mention desert badlands kind of things.
    http://fineartamerica.com/featured/space-exploration-nelson-nieves.html
    Wow that really is impressive work. Thanks for sharing !!!
    edited January 2017
