Daz Installer file totals fluctuating
My Daz Installer file totals change from time to time with no indication what was changed or why.  Less files than before.  What is happening?
  • Which tab? Are you installing content with Connect?
  • Ready to install tab.  I manually install my files.
  • That should not change unless you add things by downloading (or uninstalling) or remove by installing, assuming the filter box is empty.
  • Wasn't sure if they ever streamline files and eliminate extraneous things without notice?
    You would still need to download them deliberately - DIM will not download stuff without being told to.
  • I will keep a watch and try to figure ouot what it's doing.
  • fixmypcmikefixmypcmike Posts: 19,742
    If an item is updated then DIM won't count the out-of-date version in your Downloads folder as "Ready to Install"
