Who is this model?
I'm trying to figure out who is the amazingly cute model in the promo renders for this pose set:
http://www.daz3d.com/i13-gossip-lies-and-forgiveness-poses-for-genesis-3-female
I'm referring to the gal with the updo bun and pink tanktop.  Her texture is definitely Ronya, but the morph is something else.  Any ideas?  Thanks!
  • AnotherUserNameAnotherUserName Posts: 2,727
    edited January 2017
    I have an idea but im not certain. I think that might be Cathy by Raiya, http://www.daz3d.com/cathy-hd-for-victoria-7 , and I believe she may have had Growing Up 3 applied to her, http://www.daz3d.com/growing-up-for-genesis-3-female-s . Im guessing this is the case because the other model is Jolina by Raiya, http://www.daz3d.com/jolina-hd-for-victoria-7, and she definetely looks like Growing Up has been applied to her.
    Actually, you may be right. It might be Ronya with growing up applied.
    Post edited by AnotherUserName on
  • exstarsisexstarsis Posts: 2,128
    I am still amazed you guys can tell these things.
  • DustRiderDustRider Posts: 2,880
    Looks a lot like Sunny 7 with a few morphs dialed in (the nose is definitely different), maybe a combination of Sunny 7, V7, and/or Teen Josie 7????
  • FSMCDesignsFSMCDesigns Posts: 12,843
    Same here. Then again there is still LOTS of speculation going on
    edited January 2017
    I think the attached image comes pretty close. It uses the texture set for Sunny 7, and Sunny 7 dialed at 38%, Teen Josie 7 at 38%, and Victoria 7 at 34%
    1000 x 1200 - 189K
    Post edited by DustRider on
  • sapatsapat Posts: 1,735
    Right?  I can't barely tell one from another and ppl here know them like they're a close family member.  That and clothing ID's.  Pfft, I'm always shocked how much stuff I own and I don't even recognize it when ppl here ask 'what is this outfit?'.  I follow the links to find out, and bam, it's something I own!  I'm like 'hey, I have that!' laugh
    I can now identify some DO models by sight, which is a bit better than when I started. But PA models? Mostly.... not.
  • regarding morph mixing:   I have a collaborator for a graphic novella project.   trying to created an original face morph from mixing such products as Josie, Aiko, Karen 7 and maybe one other.  ...we are too far apart to network or share hard drives.   Do we each have to own all these identical products to load a morph one of us makes and sends to the other?   ....or can the morph mix just be saved into the G3 base and then be reloaded to produce the exact same new character by each of us whenever we need to use it, even though one of us doesn't own the exact set of character products the morph mix was originally made from ?
    In order to comply with the licensing agreement, you both need to own the products.
