Toon Nursery - need help
I bought the absolutely delightful Toon Nursery but am unable to have it show up when I use the 3D Delight version.  I can open the iRay version, but I don't have a Nividia card so it doesn't exactly work.  When I try to install the 3D Delight set all that I can see in my preview screen is the environment bubble (not sure what it's called).  In the scene menu it shows the nursery, sunlight and the environment. I'm not sure what I'm doing wrong, never had this happen before.
  • I bought the absolutely delightful Toon Nursery but am unable to have it show up when I use the 3D Delight version.  I can open the iRay version, but I don't have a Nividia card so it doesn't exactly work.  When I try to install the 3D Delight set all that I can see in my preview screen is the environment bubble (not sure what it's called).  In the scene menu it shows the nursery, sunlight and the environment. I'm not sure what I'm doing wrong, never had this happen before.
    When I load mine it's on the outside of the room. You have to zoom in or select the wall and hide to see the inside.
  • RainRain Posts: 353
    Well silly me, I tried zooming out.  Thanks, I'll give it a try.
    No problem. I hope it works for you. It's a great set.
    850 x 1105 - 2M
    It sure is.
