Assets for previous files suddenly missing with no change?...
After updating DAZ studio to the new build, all of my previously saved files have assets missing. I am then prompted to download them using DAZ Connect. Where did the assets go? I changed nothing. My content library is in the exact same setup that it was when I made the files.
-DrDrk
Post edited by drakkendark on
Have you checked if the settings in the Contend Directory Manager still include the directory where you have installed the content?
Which version of DS were you using before? had you already switched to the PostgreSQL database or - if you were on 4.8 or earlier - were you still using Valentina?
I ran DIM installing all updates and newly prchased items. When I opened DAZ again, DAZ connect was an option uder my DAZ studio tab in my content tab and DAZ started claiming that assets were missing.
Not sure why. I did not delete anything.
I am unsure of what version I wad using before the update. DAZ tells me that the same assets are missing every time I open the file. Even after I install the content through DAZ connect and then save the file.
-DrDrk
If you hover the mouse over a saved file so that a tooltip appears (assuming they are not turned off in Preferences), or look at the Info tab at the bottom of the content pane with a file selected, it will tell you which version it was saved from.
