Can Veins be Visible in OpenGL?
I have Vascularity HD for Genesis 2.  Visible when render in 3DDelight or Iray    but i don't see them at all in OpenGL. Is it possible?
    In a word, no.
  • nokoteb99nokoteb99 Posts: 943
    jestmart said:
    In a word, no.
    Can you explain the reason why it doesn't work?
  • BejaymacBejaymac Posts: 2,002
    From the sounds of things they are HD morphs, from what I understand the HD part only appears at render time with 3DL or Iray, OpenGL probably can't cope with the HD system which is why nothing shows.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    edited January 2017
    HD morphs can show in preview, you need to increase the SubDivision level in the Mesh Resolution group in the Parameters pane. Bear in mind, however, that every increase by 1 will quadruple the polygon count. I think 3 or 4 will give the full detail of the Vascularity set.
    edited January 2017
    Thanks!!! Worked like a charm
    Post edited by nokoteb99 on
