How do you pose hands to Grip? Was HandGrip ever updated?
There used to be a plugin called HandGrip back in daz 3 i believe. I even bought it.  But it no longer works with newer generation figures like Genesis 2 and it no longer even works in DAZ 4. It's not even in the store anymore.
Is there another plugin to help with gripping things OR is the only solution to get a hand pose package with approixmate gripping poses and modify them as neeeded?
  • I can't recall if they come with the base or with the Body Morph sets but if you have the right set there should be controls on the hand and figure nodes under Pose Controls>Hands in the Parameters pane. You can also multi-select finger bones to adjust all together.
  • nokoteb99nokoteb99 Posts: 943
    Thanks alot. I'll look into it!!!
