spot render just a checker board image and final render issue
Hello - I am pretty new at this but suddenly having an issue when I try to spot render. All I get is a checker board image where i try to spot render. My final render also looks very poor. I wasn't having this problem a couple of days ago and haven't messed with the render settings as far as I know. Any suggestions for this newbie? Thanks
  • Poor how? I assume the area you are rendering should have content - have you perhaps turn Visible in Render off in the Parameters pane for the missing items?
  • Drogo NazhurDrogo Nazhur Posts: 1,340
    I'm having the EXACT same problem but it is ONLY happening in IRAY. And, it also started happening last night. Prior to that I was having no issies with rendering in IRAY.
  • Hi Richard. There are a lot of items in this scene but they all seem to be on. When I try to render it, it starts but after a few hours the % is still at 0 - although it lists many 'iray iterations' and the clock is still tracking - I've left it to work by itself for several hours and over night and when I come back - the rendering image box with the % is gone - as if it finished but the render looks very very grainy like it was stopped early in the process.
  • Does it work if you take a balnk scene, create a new primitive (Create>New Primitive) and render that?
  • I tied a spot render on a primative in a new scene and I got the same checkerboard thing.
  • Do you have Depth of Field (DoF) turned on for your camera? I seem to recall that can sometimes trigger odd results.
  • In trying to fix this I deleted the camera and was just rendering from perspective view. I had the same problem both ways. I have the problem on old renders still where spot render worked a few days ago  -arg....
  • ok now it works in a new scene and in previos scenes. I didnt change anything from when I was trying and it wasn't working but I will take it. thanks for your suggestions
