No longer can Rig
Hey I'm running daz studio 4.9 and for some reason, the menus have switched and dont show everything. For example: my menu use to be File, Edit, Create, Tools, Render, Connect, Window and then Help but now its all jumbled up and then Edit->Object->Rigging->Convert Prop to Figure is gone along with the other stuff. Now all that is under Edit-> Object is only Edit->Object->Change Parent. I'm trying to turn my object into a weighted map figure so i can add my own joints and what not but now i cant do that. Whats going on?
  • Cris PalominoCris Palomino Posts: 13,051
    edited January 2017
    Something external to Daz Studio proper caused the file that stores the menus for the session (and presumably the other layout related files) to either be deleted or become corrupted; e.g. a plugin, system update, system restore, overzealous anti-virus, etc. Window > Workspace > Select Layout... > Accept should restore the default configuration of the layout that was in use prior to the deletion/corruption.
    If the layout has been customized and is of particular importance, Window > Workspace > Customize... > Import... provides options for restoring individual pieces of the UI, like menus and actions.
    Post edited by rbtwhiz on
  • ok thanks a bunch! it worked and i'm happy now!
