Something wrong with the Gianni 6 Pro Pack Bundle
Hello again! :)
Yesterday I bought the Gianni 6 Pro Pack Bundle for Daz 4.6... I loaded up the Gianni 6, I load up the genitals, but when I put on the texture, the hips and genitals texture are the only ones that are found... The rest of the body's texture doesn't blend with the hip's and genital's texture... I just downloaded it and installed it thru the Install Manager... Everytime I put on the texture for when using the genitals, it says some texture files are missing. I would redirect the files manually searching for them in my computer, but this is a cloud... There is nothing in the folder... Am I doing something wrong?
  • vwranglervwrangler Posts: 5,063
    If you're trying to apply Gianni's genital material and not Nevio/Michael 6, you're in the wrong folder, or trying to apply the wrong item. ("Nevio" is another name for the default Michael 6 texture set.)
    In the screen capture you show above, there's a folder labeled "Gianni 6". I'm guessing that his options are in that folder, rather than in the general folder you're looking in.  (I don't use categories or Connect or Smart Content, so I'm guessing a bit here.)
    You could also try just searching the word "gianni" in the white "enter text to search by" box at the top of the display, and that should exclude the Nevio items in its results and give you the results you need.
  • Thanx! That was it! ;)
