Cyberpunk City
If someone who has this could please take an overhead render of the set? It doesn't have to be a good render, I'm planning on picking this set up this weekend and I wanted to know what the layout was like.
Thank you :)
  • pdspds Posts: 593
    Here you go...
    900 x 450 - 150K
  • pdspds Posts: 593
    This one might be more helpful.
    1728 x 996 - 783K
  • kaotkblisskaotkbliss Posts: 2,918
    Thank you so much pds, very helpful indeed :)
  • pdspds Posts: 593
    You're quite welcome. :-)
  • radiuozradiuoz Posts: 14
    does it come with lighting?
    I've seeing on the store images some beautiful night lights. Doeas it come with those light presets?
    Thanks in advance
    It doesn't have a seperate light set. The scene uses mesh lights for all it's lighting (ambient for 3DL and emmissive for Iray)
  • Joe WebbJoe Webb Posts: 842
    No lighting and no presets. Many of the signs are emissives so it looks more dramatic in a darker environment, but it looks perfectly fine in a daylight setting too.
    I just used it for a darker image. All I did was use DimensionTheory's iRadiance Light Prode HDR and set it to low light, then bump up areas with Marshian Light Projection and some spots. Really though you could just use spotlights with color and maybe a Distant Light. It also comes in a 3DL material set, but I haven't used that yet.
