Can part of a prop be erased?
Hello!
I recently downloaded a lighter prop, it's in .obj format... I loaded it on my Daz 4.9 and two lighters come up, two lighters which are connected, one opened and on closed. Is there a way to erase the left lighter? I only need the open one! As always! Thanx for the info! Couldn't get anything done without this forum!
  • barbultbarbult Posts: 27,471
    You can use the Geometry Editor tool to select and delete polygons from the object.
    Incredible! Thank you! :D
  • macleanmaclean Posts: 2,438
    It sounds as though the open lighter could be a morph. In other words, the lighter is closed, and the morph opens it.
    If you can separate them and export one, it could be imported as a morph.
