Scene loading time taking a long long time
This discussion was created from comments split from: Scene loading time taking a long long time.
  • Hi,
    Sorry, but I have a big problem with DAZ studio.
    One standard character (ex.Genesis 3 ) open to slow. Example 3-6-8 min.
    (The render, not Lray is approx. 2-3 hours)
    Nothing backround, nothing cloth, nothing hair, etc. Only character.
    My computer is:
    New Apple Macpro (above)
    2.7GHz 12-core with 30MB of L3 cache
    64GB (4x16GB) of 1866MHz DDR3 ECC
    1TB PCIe-based flash storage
    2 TB Buffalo HDD (Firewire, external)
    Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM each
    Thunderbolt display
    Software:
    DAZ Studio 4.9
    The Folders:
     Runtime: 838 GB
    data:  138 GB
    general: 5,8GB
    presets: 4,5GB
    Enviroments: 3,8GB
    Tutorials: 1GB
    Summa approx: 1TB
    Unfortunately i don't know, that to which character
    we owes (data,obj,texture, etc...)
    I do not dare to transfer the libraries because of this.
    Somebody would can help me, what I shall make how?
    Many thx,
    Best Regards
    Joseph
    alias
    dettyjoe
  • mikael-aronssonmikael-aronsson Posts: 607
    edited January 2017
    Do you load the assets from the Firewire HDD ? Firewire is not slow by any means but compared to a normal built in HDD it's not very fast still should not take minutes to load it, but if you have temp files and other things on Firewire also it could cause problems.
    Is it only G3 that is slow, if you load a G2 character, is that slow also ?
    Do you mean that it takes 2-3 hours when click the render button using 3DL to render a single G3 character ? if that is correct then there is something very very wrong with the computer.
    The usual questions.
    1 - Was it faster before or it been like this all the time ?
    2 - Kind of same question, have you just installed everything or was it faster with older version of DS ?
    Have no idea how you do it on a Mac but there must be some tool (like the task manager on Windows) to show the CPU load when you render, check if it use 100% or just a little, check the settings in the renderer so you don't have some crazy sampling or something that makes it take long time.
    When you load the G3 check where the bottle neck is, must be some tool to do that on a Mac also, is it just sitting there when you load G3 or is the CPU or HDD up through the roof.
    Post edited by mikael-aronsson on
