Troubles with d-former export/import
Hi, guys!
I made a d-former using node weight map (i deleted d-former field, cause i don't need it; i used symmetry). When i saved the file as "D-Former(s) Preset..." i found it in my folder with .duf.tmp extension (but i saved it with .duf extension). And when i want to load this d-former into a scene, Daz studio doesn't see it in my folder((. Help, somebody!
The .tmp file would be a working copy while the save was proceeding. You could try deleting the .tmp extension and see if the file works. I would suggest in future not deleting the field but simply moving it out of the way - though deleting it shouldn't break the save.
Yes, looks like deleting field is causing this trouble. Thanks.
