Body of Light product
I just purchased the Body of Light for Daz Studio, it doesn't appear in my product list! I pulled up a figure and found it in smart files under the lights category! I tried to use it and these little square dots appeared all over the figure! I am not sure how to use this product! Could some one help explain how this works?
The PA's thread may help http://www.daz3d.com/forums/discussion/140716/body-of-light-commercial#latest
Hi jodycour. Did you get this set working? The lights load to the figure just like you load a piece of clothing. Use the Aux Viewport to do test renders. Post here or the in the commercial thread above if you are still having trouble.
It is working, I just don't know what I am doing with it! When I render it there is too much lighting on the figures! I am trying get my figures to have a glowing transparent affect on them! This the reason I purchased it but I haven't been successful at accomplishing this feat yet!
Hi jodycour, I'm here to help. This burn out or blown out effect could be from other lights in your scene. Make sure all lights are all turned way down and, if there are no lights or emissive surfaces being used, make sure your Environment Map and Intensity (in render settings tab) is set to .10 (or close to it). Let me know how this goes.
If you loaded more than one Body Of Light preset to the figure this could also give similar results. The ReadMe explains how to delete the lights: http://docs.daz3d.com/doku.php/public/read_me/index/36575/start
