Help! Everything in the scene vanished.
LigeiaWestwickDesigns
I don't know what I did, (I am assuming I hit some key) but I was working on a scene and everything vanished from the scene in the Actors,Wardrobe and Props tab. Even after resetting factory defaults, when I load a figure it is not visible. In surface selection I can see yellow outline of the shape but that is it. Everything is visible in the Posing and Lights and Cameras tabs, just not the Actors,Wardrobe and Props tab.
I would be greatful for any help getting my scenes visible again.
Thanks
Is the viewport closed? Do ypu still have the tab labelled Viewport? If not you need to reopen the pane from Window>Panes(Tabs)>Viewport and redock it, or simply reload your layout from Window>Workspace>Select Layout (but that will remove any other customisations you have made to the UI).
Thank You. I just went in and rebuilt my layout and that did the trick. I also saved my layout this time :)
