tiling textures in daz studio 4.5
gibrril_fa945a6ceegibrril_fa945a6cee Posts: 550
Hi,
I was wondering: is there a way to increase the numbe of repeats of a tilable texture on an object in daz studio 4.5?
I remember importing a plane into daz studio 3 and applying a tilable sand texture to it. Using the surfaces tab I increased the number of texture repats in both the x and y axis untill the resolution was ok, but I can't find that function in the surfaces tab of daz studio 4.5
In daz studio 3 it can be found under the advanced section of the surfaces tab and it's called "tiling" Where can this be found in daz studio 4.5?
Thanks a lot,
Me
    Assuming you're using the default shader ("DAZ Studio Default") it's listed as shown in the image below.
    399 x 309 - 15K
    It's in exactly the same place as far as I can see. Note that if you're showing the complete surfaces parameter list instead of just the "Tiling" subhead, I have sometimes seen the list come up back-to-front, with the tiling settings near the bottom instead of near the top.
    I've also seen the tiling and other new-in-DS4 parameters just plain not show up in the Surfaces list if I've loaded something saved in D|S3 or earlier, but I can't think how this could be your problem. Try re-applying the dzDefault shader (you'll find it in the "Shader Presets" folder) and see if that helps.
  • gibrril_fa945a6ceegibrril_fa945a6cee Posts: 550
    Hi all,
    Thanks for the quick replies!
    It was the default shader that did it.... I forgot to apply it, hence the tiling section was missing... Thanks a thousand!
